carrti01
- March 5, 2014
- North Fork, CA
- 1993 Explorer Eddie Bauer
Hello all. This is my first post here so thanks in advance for any help you can provide.
A little background.
I bought this baby for $900 from a person who didn't take very good care of it. It didn't even have transmission fluid in it when I first looked at it.
From time to time the car won't start after about the 4th or 5th time starting it in the same day. If it let it sit for a while and go back, it will start right up.
A short time ago I noticed it was having trouble accelerating. As I accelerated up a hill I would hear a "click shhhhhhhhhhhhhhhhh" sound from the engine for about 3 seconds associated with a barely noticeable loss of power. Last week, while driving, i experienced a total loss of power several times while going up a steep hill. The acceleration would cut out and the check engine light would come on, then it would kick back in and the check engine light shuts off. It did that all the way home. I replaced the spark plugs, spark plug wires, air filter, in-line fuel filter, and I haven't experienced those problems since.
However it didn't start again the other day after driving it around town to run errands. I came out of the store and the engine just chugs but won't start. I tried starter fluid spray and it helped a bit but just wouldn't turn over all the way and smelled bad like starter fluid from the exhaust while I was cranking. The fuel pump DOES turn on when I turn the key, I can hear it in the gas tank turn on, and the fuel came spraying out from the connection near the injector when I checked to make sure it had fuel up at the engine. I had a friend get underneath and tap on the starter with a hammer while I tried cranking it some more, still no start. Got it towed home by AAA and when I got home it started right up. Any Ideas anyone.
