79383
- July 26, 2010
- Vancouver, Washington
- 95 XLT
Hi I have a stock '95 Ford Explorer 4wd 4.0L EFI 6cyl. I am having trouble with starting the vehicle. I go to start the car and the engine sputters and dies. I then go to start the engine again and it has no problem starting. I give it a little bit of gas and it will start rough and return to normal.
Here is what I have done since I have owned the vehicle in a little under 2 years I ahve replaced the Heater Core Twice(Replaced this when I bought this vehicle and replaced it again in January of this year due to it going out again.(Really need to get a copper one made.) ) I have replaced the temperature sensing unit and the Starter, Starter Solenoid. Also removed the catalytic converter since it went bad and replaced it with a straight pipe. I have also done 3-4 Tune-Ups on this thing that included and Oil Changes, Spark Plug replacements, Spark Plug wires, fuel filters and replaced a few worn Hoses. I have noticed during driving in the last 6 months that very rarely the Check engine light will flash on for 2-5 seconds and then go away tried to read the code the 3 times it has done that and nothing shows up.
I think it could be one of these things causing this problem: Crank Sensor, Idle air control valves, TPI. I also noticed when I went to leave this morning my throttle cable was stuck. I haven't checked but I think it is starting to go out. I appreciate any help you can give. This is my Daily driver and I need it to continue to run.
