1993 Ford Ranger won't start. | Ford Explorer Forums
ggarden City, MI
1993 Ford Ranger
:mad: i have a 1993 ford ranger and last week i was on my home from work and in the middle of traffic it just turned off so i pushed it off the road went and put 5 gallons of gas when fueling i noticed gas poruing out of the filler hose it had a crack in it so pushed it home droped the tank when i was pulling the lines off i broke off the fuel sending unit line going into the gas lines. so now i replaced the filler neck and sending unit and now i hear the fuel pump working and it cranks over but doesnt start any ideas anyone?
engine specs
2.3l 4 chylinder engine 5 speed 150000 miles tryed starting the battery, oil, abs, seatbelt, engine, light was on now just the oil, abs, seatbelt light just come on
i replaced the filler neck, sending unit, fuel filter and it still didnt turn over so i checked the shrader valve still has pressure and i can hear the pump kick on the emergency shut off is not triggered and the tank reads half full and the batterys good any ideas guys?
i checked the fuses and the coil pack and sparg plugs all good. the spark plug smelt like gas. it didnt fire up with starter fluid. and it has a vacuum. maybe the injectors?
check the distributor cap and rotor button. Finally had to replace mine on the side of the road yesterday
