1993X Sport HU removal problems....HELP! | Ford Explorer Forums
geosnooker2000
Somerville TN
'10 Eddie Bauer V8 4x4
Tryng to install my son's Christmas present today. A Sony HU. The problem I'm having is removing the factory HU. It is the "High-Level Audio System - Page 20" in the orriginal operating guide. As an aside, I believe that comes with an amp in the back right trim in the cargo area, but without a sub-woofer. There is one HU that is higher grade in the Operating Guide, but 2 HUs that are lower.
Here's my problem at this point. The Haynes manual says to remove the HU, you must first remove the instrument cluster trim panel (see Chapter 11). Last night (it was freakin' cold) my son and I.....
1) doubted that it was nessesary.
2) tried to remove the trim panel, but ran into trouble above the steering column, and all the electrical connections you would have to unplug to remove the trim panel
3) went back to trying to remove the Head Unit with 2 pieces of coat hanger.
4) the HU is moving with the trim panel, like it's primarily atatched to that. Not the dash innerds.
5) One of us would hold the trim panel away about 3 or 4 inches (all we could muster without tearing something up) while the other stuck the home-made puller tools into the HU and tried to pull it out. You could actually see the coathangers going into the keeper bracket and colapse inward like it's supposed to, but it just wouldn't budge. We tried it with the panel pulled out that way AND with the panel back in place.
Where are we going wrong?
Ok, after kicking around the site, I dicovered
http://www.explorerforum.com/forums/showthread.php?t=152093&highlight=remove+instrument+cluster
where in post #1 it is stated that the front dash trim just comes right off. Well how? Does the radio face come off with it? Because the radio face is on the outside of the trim and is BIGGER than the whole in the trim behind it. I'm getting pissed, and about to break something. I keep pulling on the trim, and the radio keeps moving in and out with the trim. I can't pull the radio out with the trim because the trim has to rotate clock-wise to get over the steering column and the radio is prventing it from rotating. AAARRRRGGGGGGGGGG!!!!!!
