1994 explorer IAC vs the 1995 explorer IAC | Ford Explorer Forums
v10gta
VA
1995 Explorer XLT
So guys, my IAC recently hit the bucket, you can only clean them but so many times till they finally fail on you. At the junk yard i picked up a IAC from another 95 explorer. I also picked up one from a 1994 explorer because they have the same exact wire harness connector and bolt up the same. The only thing is that on the 1994 its a bit bigger.
Heres the 1994 one
getimage.php
Heres the 1995 one
getimage.php
The one from the 94 will bolt up perfectly to the 1995 explorer. My question is, how compatible is it with the 95? I cant afford one new, the one at autozone was over 100 and the one they sell for 40 is for the newer explorers like 97s. So i got two IACs from the junker for 16 bucks.
Im currently using the one i took off the 95 explorer from the junkyard but i dont have much faith in it, you can only clean it a number of times.
