ERICC
- April 1, 2008
- Sydney
- 1994 limited
Hello there, I have been given a 1994 explorer. On the the Anti lock brake "block valve" there are three ports , best descriped as left, centre and right. Question. Should not the centre port feed the rear brakes (drum) and the left and right ports to the respective front wheels. Currently the brake line which runs from the centre port is connected to the drivers side caliper. The left port / brake line runs to the rear brakes and the right port is connected to the passenger side. This does not look correct. Should not the centre port on the valve block feed the rear ?... and the left port to the drivers side?. Note : the centre port is larger in diameter, left and right smaller but equal size.
THANKS, Eric Cape Breton, Canada
