Did the drums come off easily?
If the drums slipped right off then your P-brake isn't the prob.
Put the gear selector in "D" not overdrive and see if it still feels like it's starting out in 2nd gear.
I'm thinking your trans is having a cold weather glitch (common) where it is starting out in 1st and 4th together.
Yes, this is possible. 4th (OD) can be added to any gear. Giving you a sluggish start. It's the 3-4 solenoid, not that it has failed just a sticky valve when cold.
Also run through the gears manually 1-2-D and see what you get that way.
If you run in Drive until it's warmed up it will clear up. UNLESS the 3-4 solenoid
is bad and left you stuck in 4th.
This will not effect reverse as reverse is also on the OD drum.
It won't damage it to run like this, but NO full throttle on the OD drum at low speeds, it's a bit weak, so take it easy until you can drop the pan a replace the solenoid.
Here's a quick thread to get you familiar with what's involved in replacing shift solenoids:
http://www.explorerforum.com/forums/showthread.php?t=121883
This can also be due to out of adjustment shift linkage as well so run through both cable adjustments first to eliminate that as a cause.
No use tearing into a trans just because the cables are out of wack!
