1994 Ford Explorer starter | Ford Explorer Forums
TannerSummers
Hello everyone, new here. I need help. I have to change the starter on a 94 ford explorer. I seen some videos but not for my exact model. I am new to this so can anyone supply tips or a guide on how to change it? Thanks
It's pretty easy. Two bolts, one upper, one lower. The lower has two nuts on it. The nuts sandwich the negative cable from the battery. Plus there's a thin wire that connects to the solenoid, it will either slide on/off or have a small screw.
Disconnect the battery before you start. Make sure you get the right starter for your transmission, it's different for a manual trans vs an automatic.
