1994 xlt 4x4 problems, no CEL | Ford Explorer Forums
w00t69
Baton Rouge, Louisiana
'94 XLT 4x4
No power, horrid gas mileage. changed quite a few things just because i figured they needed to be changed (spark plugs and wires, fuel filter, air filter, O2 sensor. Last thing i tried was the fuel injector pressure regulator, that seemed to make it worse.
Now... not sure what it could be.
Assuming 'no power' means that it won't accelerate... Have you checked the fuel pressure? Also, pull the codes. There can be a code even if the CEL is out.
yeah no power means i press the gas and it just bogs down and doesn't go.
Also there's a tsst tsst sound ( best way to describe it) high pressure air type sound coming from somewhere along the exhaust.
I'll take it tommorrow to get some codes
change the cat i don't know how many miles he has but if the cat is blugged it will make a hissing sound like a crimped exhaust pipe factory use to say change cat at 50k
If you think it's the cat conv, you try smacking it with a rubber hammer. Sometimes disloging something can make a difference.
