1995 - 2001 Ford Explorer Steering Column Shift Tube Assy with Bushing SET | Ford Explorer Forums
1Aauto
EF Vendor
mass
92 explorer
This replacement 4 piece steering column shift tube assy is just what you need to get your vehicles steering coulmn in good working condition again!
As this assy wears, it causes the sticky and wobbly feeling in your shift lever. Also, if exposed to moisture, this can cause the assy to rust up causing the normal smooth shifting motion to become hard to move.
Features:
Located in the center of the steering column ( See location diagram)
Steering column will need to be disassembled to replace parts
Consists of the following pieces:
(1) Shift Tube
(1) Selector Plunger
(2) Selector bushings
Replaces dealer part numbers: F3TZ 7L278 A, F3TZ7L278A, F57Z 7212 A, F57Z7212A, F7DZ 7R264 AA, F7DZ7R264AA
Built to strict quality control standards
Direct replacements
Fits all models with or without tilt steering
Correct for models with Column Shift
Does not fit models with floor shift
This Steering Column Shift Tube Assy is a great replacement part and provides a good cost savings over the price of dealer parts.
This part replaces:
OE #: F57Z-7212-A, F7DZ-7R264-AA
Can you re-post the diagram that you reference in your write-up? When I try to go to it, I get redirected to a site that is trying to sell me something. I have this issue with my Explorer and would like to see the parts that need to be replaced. Thank you.
