1995 explorer v6 towing advice | Ford Explorer Forums
Blktopsil80
Ok so i have a 1995 ford explorer xlt v6 4.0l...now i want to trailer my track car which with trailer comes out to about 3700lbs with trailer....so what do i need suspension wise to be able to support the trailer? and then what should i buy for the transmission?
Suspension wise you should not need much or anything. Tongue weight should be no more than 10% at 370 pounds your explorer should handle that.
I would make sure to have a transmission cooler. Do not tow in over drive.
ok i will def look into a bigger cooler than the stock one...now i realize that my explorer has saggy ass syndrome...what should i replace?
Leaf springs
Please get out the owners manual, and determine your max tow rating and GCVWR, which will depend on your drivetrain, and whether you have the factory tow package. If you do not have the factory tow package, you likely have limited axle gearing, and 3700 lbs will be over your 3500 lbs rating. If that is the case, and you are towing with only yourself, and nobody/nothing else in the truck, you might be OK at 200 lbs over your limit. But if you will also have passenger and cargo in the Explorer, you will not be happy.
If you have the factory towing package, then you probably are good for at least 5000 lbs max tow rating, which will allow for 3700 lbs of loaded trailer and 1300 lbs of passengers and cargo in the truck. In that case, you simply need to figure out what you need to do, ralated to maintenance and degradation on a 15 year old truck.
also a trailer brake controller or sway control device may help
