1995 Transmission Mystery | Ford Explorer Forums
Cherokee kid
1995 Explorer
When I start out from a stop ONLY after just starting the car from Park, the transmission will not shift out of first. If I manually shift it into second and then manually shift to drive it will shift and continue to shift properly out of first like from a stop sign until I put it in Park again.
If I start out in second after being parked and manually shift to drive, again no problem from then on.
I had the transmission flushed by a transmission shop and the transmission shifts smoothly at all other times.
What do you all think?
