1996 3.0L Aerostar XLT to AWD swap. | Ford Explorer Forums
Mark Embury
OR
1996 ford aerostar xlt
I have a ext 4.0 drive train I can get cheap. What do I need?
I know a guy in Salem OR who has a 93 AWD, I just want to keep my 3.0 V6. What transmission do I nerd?
My van is the shorter one 2 wheel drive 96, can I use my transmission?
Easier to find a 4 wheel drive transmission. You could convert your transmission if you take it completely apart to change the output shaft and tailhousing. Front subframe is a 6 bolt swap. The engine comes out of the van a lot faster through the bottom to swap it to the new subframe.
So I can keep the the 3.0 but drop it out to bolt to the set sub frame of the 1993 extended sub frame?
The bellhousing of the transmission for the 3.0L engine is different than the one which is used with a 4.0L engine. The transmission is different too. The 3.0L uses a 4R44E transmission in the 1996 model, and a 5R44E in the 1997 model.
Look at the pictures that I posted of the engine removal on my 94 awd van. The subframe holds the engine, and front axle as an assembly. I picked the body up off of the engine, it took 2 people working on it about half a day. The transmission, you can use one from a 4.0L awd van if you swap the bellhousing from the 3.0L transmission.
Can't find your vans pictures. Would like to see them. Thanks.
