brindlpitt1
- November 22, 2013
- Ohio
- 1996 explorer 4.0
Well like the title says I have a 1996 ford explorer 128,000 miles.
starts just fine , has no check engine light.
sometimes when you start it it revs to 2500 + rpm not always
But what it always does when you put it in gear it revs then idles normal then revs again then idles normal and if your not holding the brake it runs down the road about 30 mph with out touching the accelerator
as long as you sit holding the brake with it in gear it will continue to rev up then idle normal then rev up ......and so on and so on and so on
runs down the highway fine, gets about 16 mpg. everything else seems normal
any one else have this problem?
what fixed it
I tried searching the forum but dint find any thing like this.
what fixed it
