1996 Aerostar with a power steering leak. | Ford Explorer Forums
terifitzp
Hi! I drive a 1996 Ford Aerostar that I bought in January 2000. I had the rack and pinion steering replaced and power steering filled about 2,000 miles ago (just under 3 months) and I'm leaking power steering fluid again, I think. It started whining and I checked the fluid to find it was empty. I can't see my mechanic untill next week. I'll have to listen and watch and fill as needed untill then. Any thoughts or advice? terifitzp
Welcome to this forum! I've renamed your thread, and moved it into the Aerostar section. It should be easy to locate the leak if it's a heavy leak. Fill up the reservoir, and check the fittings for leak.
