1996 Explorer JBL upgrade replacement parts? | Ford Explorer Forums
Harro
Tampa Florida
1996 Eddie Bauer V8 4x4
I got a 1996 Eddie Bauer Explorer with a JBL audio upgrade:exp: . In the back of the car if you are looking in from the outside, there is a 6 1/2 inch sub on the right. when removing the panel i found there was an amp with 2 inputs and 1 output for the subs and the amp was wired to what I thought was the AM/FM tuner. The sub was not working and I tested it later on and found out it was not actually the 6 1/2 inch sub that was broken, but it was the amp. I removed the cover of the amp and saw that it was burnt up on a certain spot. I don't want to go get anther amp and get stuck with rewiring the whole car, any idea where I can get a replacement of this amp? If you want pictures I will get them later
THANKS!:salute:
Pick n Pull, Junk Yards Dog, or similer is prob you best bet for the price, but I'm sure you can find them on the Ford Parts Network or similer.
Honestly though you should really consider upgrading to aftermarket if you want decent SQ.
Whats a decent but not toooo tooo expensive amp I can replace it with?
