1996 ford explorer issues | Ford Explorer Forums
sean kane
Arlington Washington
1996 Ford Explorer
Ok ran a diagnostic with a snap-on MT2500 scanner.
I have the following:
B1398 1 touch window down relay circuit fault
B1352 ignition key in circuit fault
P1781 4X4L SW out of range
P1824 4WD electronic clutch relay circuit fault
My auto window does not work.
My 4X4 does not always work but sometimes it will, and the 4X4 and 4X4L lights flash 6 times all the time.
Can anyone tell me exactly where these relays are so I can remedy my problem?
I really want to get the window fixed and the 4WD.
I would appreciate any insite.
Thanks for the info but sadly thats not the info I need. There are many relays under the dash and all over the explorer for that matter. I just need to know if someone can tell me exactly what relays are causing the problem and exactly where they are located. Thanks again.
No one can tell me which relay unfer the dash is causing my issues?
I think you answered your own question. There are a number of relays that operate more than one system. GOOD LUCK
