John Quinn
- August 14, 2019
- Location
- Culleoka, TN
- Culleoka, TN
- 1996 Explorer Limited V8
Hello all.
I have a '96 V8 Limited AWD. The rear defrost is not functioning. When I press the switch on the dash, there is no "click" and it does not stay depressed like the fog light switch below it.
There's no indicator light when pressed.
I'm assuming this is a momentary switch and fires a relay and timer.
I can't find a blown fuse in the fuse panel and I can test the switch and bulb with a meter.
Does the indicator bulb have to be good for the switch to function?
And if the switch is functional, where would I find the relay?
Thank you in advance.
