Rob&Robby
- March 14, 2010
- Las Vegas, NV
- 2011 Explorer XLT 4x4
It had been running fine. My son cranked it up today, and a few seconds later, it shut off by itself and wouldn't start again..... I checked it for spark by pulling off one of the spark plug boots and doing the old screwdriver trick.... No spark. I had a friend, who seems very mechanically inclined come check it out. He did some tests with my voltmeter and the coil pack, and according to him, the coil pack is good, but not getting any power. After some searching on the internet, he suggested I change the Crankshaft Position Sensor (CKP), so we did.... Still same issue. No spark. I purchased a Haynes manual for it, and have been doing some reading. At this point, everything seems to be pointing to the Powertrain Control Module (PCM / EEC-V). Does that control whether or not the car gets spark? Could it be the relay? How do you test the PCM and/or the relay? Everything else works. Car turns over, lights, accessories, etc.... Just won't start. What else might it be, or what else should I look at???
Rob
Rob
