travsbengals
- March 23, 2012
- Charlotte, NC
- 97 Explorer OHV 4.0 4x4
Hello guys
I'm replacing the head gaskets and most all the other gaskets on my 97 Explorer 4.0 OHV. Never done anything like this before so I'm taking my time and trying to screw up as little as possible
I've gotten down to removing the exhaust manifolds from the head. I started on the passenger side. The bolts holding the exhaust manifold to the head I got loose. The bolts holding the manifold to the exhaust are not budging. I've been spraying PB blaster on there, heated it up, used impact wrench, nothin. I've just been working on one of the 2 bolts pretty much so far. I really don't wanna break the bolt(s). - http://s1168.photobucket.com/albums/r489/travsbengals/?action=view¤t=P1010014.jpg
I'm wondering if I have to actually remove those bolts though.
2 of the bolts holding the manifold to the head are studs. One of the studs loosened inside the head so I can probably just take it out, the other one doesn't move yet. If I can get the other stud to turn, can I remove the studs from the head and not bother disconnecting the exhaust manifold from the exhaust? Can I just leave the exhaust manifold where it is and replace the head and manifold gaskets, then put the head back in?
This pick shows one of the 2 studs I'm referring to that screw into the head, top left nut(stud)
http://s1168.photobucket.com/albums...ravsbengals/?action=view¤t=P1010013.jpg
