1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
CHECK HERE FOR GREAT PRICES 1999-2001 Ford Explorer Exhaust Manifold for V8 5.0L Passenger Side
FREE SHIPPING IN THE LOWER 48 STATES!!!
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement.
Specifications:
RH Passenger's side
2 bolt flange
Corrosion resistant
Replaces original manifolds that are cracked from thermal expansion and contraction
Strengthened and redesigned in the vulnerable areas of failure
Has provision for EGR tube
Note: For 1998 production vehicles: You can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
HOLLANDER #: 327-1846R
DORMAN #: 674-329
Specifications:
RH Passenger's side
2 bolt flange
Corrosion resistant
1 Year Warranty
This part replaces:
DORMAN #: 674-329
