rgurleyjr
- September 5, 2014
- 1999 Ford Explorer
First time post. This will be long, but really need some help. Note that 2 months ago, her son did a complete tuneup, new plugs and wires.
Our church bought a 99 Explorer for a lady who hit hard times with her health and could not work. Other than little stuff, it ran good for 6 months or so. Just last Sunday, she said it wasn't running right and wanted to stall, shaking, etc. The truck was still warm, so I started it and there was a noticable misfire at idle. The only code was P0304. I did not drive it, just told her I'd come back the next day.
The next day on Monday, I pulled the #4 plug and it was sort of red/rusty looking while another plug was still new looking. I also noticed that it ran fine when cold, but within a few minutes of running is when it started missing. Also the coolant reservior and radiator smell of gas/combustion smell. Also after running for a while, there was consistent bubbling in the reservior. No white smoke, but the tailpipe is very clean inside. I filled up the radiator and reservior and told her I'd do research and get back with her, her cooling system was low
Well, the whole time until today when she dropped it off at my house, I thought she had a OHV, not SOHC. So this week, I did a bunch of research on this site and others about OHV explorers and my symptoms above. I was convinced her problem was the lower intake gasket leaking coolant into the combustion chamber as that is a problem after much reading. BUT.....now that I see its a SOHC, it appears that no coolant goes through the lower intake at least per someone on this site.
So with all of that said, this appears to be a head gasket or head problem, right? I have never owned a ford with the 4.0 engine. I also read just now about these engines and timing chain nightmares. If the above does indeed sound like a head gasket or head, is it super hard/not a good idea to try and fix it in regards to the problems with the chains? I have not done a compression check yet because I thought it was a leaking intake gasket and didn't see the point. Any help or confirmation would be appreciated.
