1999 Ford Explorer starting issue | Ford Explorer Forums
efiles123
1999 Explorer
One cold morning the fuel pump would not operate. When turning the key to run the volts to the pump (with plug disconnected) was 8.6 for a second, then dropped to the 6v range. I took the inertia switch from the firewall and back probed the wire going to the fuel pump, getting 12 volts. I went back to the fuel tank and measured the voltage with the key in run position, and read battery voltage. The car started, and has not failed in 3 days. I know it will quit again. I was thinking of replacing the inertia switch and fuel pump relay. Does anyone have more suggestions?
Fuel pump relay and Pcm relay are now replaced. Work good for a few days but started to act up again today when i started it and ran for couple seconds and shut off. I primed it up by turning key part way and it fired right up...
What is the amp draw of the fuel pump? Compare it to the manual specs. If excessive draw the pump or wiring could be worn out.
yeah could be high resistance in the wiring not too uncommon
