joesaiditstrue
- August 12, 2007
Yesterday on my way to work, I started having some problems with my truck, which is a 99 Ranger 6-cyl, automatic
the ABS light turned on, and has not turned off yet, unless I turn the truck off. Also, the overdrive light now blinks on and off, and doesn't stop unless I turn the truck off. And, the 3rd problem is the speedometer no longer functions, and finally the last problem is the transmission doesn't seem to shift properly anymore, as it seems to slam hard into the next gear when it shifts
All 4 of these things happened simultaneously, what would cause this? I've google'd all of these problems and i've came up with quite a few threads on many other forums, with people exhibiting the same types of symptoms, which most attributed to the ABS Sensor on the rear end. However I came upon another post where someone had these exact problems, replaced his ABS sensor and it didn't solve the speedometer or the hard shifting problem
Any ideas what would've caused this, and can it be fixed without extensive costs?
thanks for any help you can give
