1st Gen 3in BL with 32s | Ford Explorer Forums
ExplorerX91
Yakima, WA
91 XL
i have a bunch pics just got around to uploading a few to my site, not an elite explorer :( , anyways
heres a couple befores stock with some newer tires.. idk noobie
http://www.geocities.com/vioed15/explorer1.jpg
http://www.geocities.com/vioed15/explorer2.jpg
http://www.geocities.com/vioed15/cleanexplorer.jpg
couple random muddin pics
http://www.geocities.com/vioed15/muddin.jpg
http://www.geocities.com/vioed15/muddin2.jpg
with bl and tires, that ones not the best ill get a better one soon
http://www.geocities.com/vioed15/explorerlift1.jpg
tell me what you think this is just the start also im going to do a write up on my bl expierence, its worth it
geocities sucks.Sounds like a nice truck
link doesn't work
just chk bakc later it does that sometimes i should switch domains but im lazy
Pics still not available and its the 14th.:rolleyes: Sounds like its real nice! Hope to see some pics soon.
pics still no work but i could see them when i went to your site...truck is coming alone nicely.
since i AM elite, i will post up one of the best shots for ya:
thanks man i need to figure out this picture stuff, urs is coming along good as well
thanx chief....as for teh pix, might want to consider becoming elite:D
Best way to go if you want to post pics :D
Yah, I wanna read your body lift experience. I am planning to do a 3 inch body lift on my first gen too, but I was am going to put 33s under it. You think those would work? On the tire chart it said minimal trimming may be neccessary, so if that was the case I was going to put shackles and coil spacers. I'm interested in the writeup, even better if you have pictures of the process.
do a search for: udmsvt gone sour
that chart is wrong, you will not be able to fit 33s without some major hacking....yeah i know a guy that did it at stock height but he rubs constantly...if you want 33s, you will need 3" BL plus 2" sl and slight trimming
what if you did 33x10.50 tires bf makes em they wouldnt be as wide as say 12.50 would those fit with just a 3"body lift. maybe they would not rub cause they are not as wide??????? i dunno i am doing a 3" bl here in like a week and i wanted to do 33's i hope they fit
i would go 32x11.5 because in the mud and what-not the extra width helps more than the heighth (if you think about it, 1" wider vs 1/2" dif in height)
