Lol nice! My most ridiculous/time consuming uses of my Leatherman are as follows -When I had to make the holes for the speakers in the back from 5x8 to 6x9. Literally cut the sheet metal one inch extra with a wire cutters (heavy duty cable cutter) like 8-10 times all the way around the hole..then, with the Leatherman moved each flap that was made back and forth over and over until all the flaps broke off and was left with a mess of dangerous metal. Used the file on the Leatherman to make it all nice and smooth lmao.
The other time was when I had to cut the port holes out for my sub box. 2 6" port holes. Drilled a hole in the center, then all the way around the hole cutout about 8 times at the edge..then used the saw blade of the LM to cut all the way around it and make it nice. I had no power tools except a drill and drill bits at this time, but had to make due with what I had! Lol I'll likely keep it forever, it's so useful when that's all you have.
