dhonnoll
- July 7, 2009
- Nesbit, MS
- 2013 Limited
I have a 2013 2.0 Ecoboost. About a year and a half ago not long after we bought it I replaced the turbo charger due to the lack of boost error and the wastegate was rattling and just basically worn out. Problem solved mostly. For the daily driver it is, it is fine. If I ease into the gas it is fine. If I Stomp on it WOT or mash hard to get on the interstate it will rev up, fall flat, dead miss. CEL flashes (which would be a dead miss) and it has no power no get up even when not dead missing. If I ease into it, smooth power. Is this just How it is? or do I maybe have condensation in the intercooler as I am seeing a lot of the F-150 EBs have?
New plugs,
New turbo charger.
Clean K&N filter
Cleaned the MAF
Cleaned the heads with a spray in type head cleaner that is supposed to be turbo safe.
No CELs just when you stomp on it especially when it is already in higher gears it just falls flat will downshift but misses. I know it isn't a race vehicle but I should be able to go full throttle if I wish with no dead misses.
New plugs,
New turbo charger.
Clean K&N filter
Cleaned the MAF
