HeavyFoot
- September 15, 2011
- Vantucky, WA
- 93 Explorer XLT 4x4
I want to mildly lift my Explorer.. it needs new spring eventually anyways. I'll get Deaver's for the rear regardless next year.
My first inclination is to simply use something like the Skyjacker 2" lift springs and a warrior shackle in the rear.. figured $220ish + shipping for those and $170+ shipping for the shocks I would need. So about $400+S&H and pretty minimal labor... would definitely need camber bushings but those are only $10 at Rock Auto, and I need to talk to my alignment shop they may just have the ones I would need anyways. I should also replace my pivot bushings at the same time...
The other thought was.. why not go with the James Duff 2.5" Stage 1.5 lift that for that extra $200 comes with drop brackets for the radius arms and axle pivots. Seems like a deal to me... except I hate grinding rivets with a passion
I've done a shackle flip on old Chevy's.. that sucked.
On the positive side.. no more rivets on my radius arm brackets as the PO had the bushings replaced and the shop that did it put new grade 8 hardware in. So I'd only have to grind the driver side axle pivot.
Did I mention I hate rivets?
What say you guys.... is the JD kit worth the extra labor? I'm a DIYer, have many hand tools, a nice 1/2" Milwaukee drill, a sawzall, and an angle grinder...
I'm shooting for installing on Thanksgiving week as I'll have it off work and that's still early enough where we shouldn't have any snow....
