2" lift alignment question | Ford Explorer Forums
wbfd331
West Babylon, New York
94 XLT
I was considering installing a 2" susp lift from skyjacker who recommends a caster/camber kit. When I went to buy the kit from a local retailer he suggested I didn't due to serious alignment problems associated with the twin I-Beam system if you don't use drop brackets, which are not available in 2" coil/aal kits.
Is this a real concern or was he just trying to sell me a 4" kit? Has anyone had alignment problems with spacer/aal kits?
I'm on a budget so I can't afford more than 1.5"-2" of susp lift with my 30x9.5 tires. Will the F150 coil seats + aal kit work as well as the Skyjacker kit considering it's less than half the cost? Any suggestions appreciated.
I don't know either, but I am curious also.
2" is considered the max you can lift without needing drop brackets. You will need new camber bushings, probably with the max degree available for our frontend. (2.5)
On my 92 Ex, I put 2.5" coils into an otherwise stock frontend, and with the 2.5 degree bushings, I'm not quite able to get it in perfect alignment. It's about 1 degree off, and I can live with that!
