lift alignment question | Ford Explorer Forums - Serious Explorations
2'91fords
los angeles
91 explorer sport
I just bought a 91 explorer and am planning on throwing in some fabtech 1.5-2" springs and shocks that my buddy gave me from a 90s ranger. will i have camber or any other alignment problems? if so, how can it be corrected without installing drop brackets? also, will a 1.5-2" fit 30's or 31's? any info appreciated.
All you need are camber shims of the proper degree to correct alignment. The shop should have them in stock, which means all you have to do after the lift is just take it in for an alignment. Otherwise, you can order them from places like Rockauto.com or get them at Napa. a 2" lift will fit 31's no problem, 32's with possible minor rubbing.
