91explorer1009
- January 14, 2004
- NJ
- 91 sport
Doing some engine work, I saw what I believe to be te FPR, near the upper manifiold pass. side, would it have a plastic housing/clasp that goes around it? Mine was half broke off and when I touched it it came off and the plastics broke, my question is, will it be okay without the plastic housing?
Second, when I engage my 91 ex into reverse, a loud clunk happens as it engages. (sounds like someone hitting metal with a hammer sort of) It is totally fine once this one loud clunk happens, but others in the truck usually ask what the hell is that. Any ideas?
I have been chasing down a high idle for over a year. Long story short, I have replaced every sensor from maf, iac, 02, act, tps, coolant temp. sensor. Always resetting my computer after. No dice, also, no vacuum leaks, good PCV valve, shop couldnt find anything. My question is, could a bad or going bad fuel pump or FPR cause an erratic high idle, and also sometimes in the cold, a low idle to a die. When it is in park or neutral it usually goes to 1500 RPMs. Driving is okay, your help is appreciated guys, thanks. And yes I have been searching the site for months...
