2000 4.0L 4WD Overheating issue | Page 2 | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
I would take a look at the fan clutch .
Test it !
By the way you are hurting your engine by allowing it to overheat 220 is way too hot in my opinion
There are many people pointing to the fan clutch. The easiest way to check if you are getting proper air flow through the radiator is to warm up the engine to normal with the hood closed and lay a shop towel over the grill. If the towel will not stay put that means the fan will not pull the air the engine needs at idle. If the air flow is adequate then the radiator is suspect for your issue.
Another Old School Mechanical/Temp Activated Fan Clutch Performance Test
Bring truck up to operating temperature.
Fold over an old section of 5/8" heater hose so it's about a foot long when doubled over.
With engine idling, and being aware of engine compartment surroundings, carefully insert the folded over hose in the path of the fan blades.
If the clutch is good, it will easily overcome the resistance of the heater hose, and act like it's a playing card on bicycle wheel spokes.
If the clutch is bad, the fan will instantly stop spinning as the engine continues to idle.
Carry on -
Good one!
I’d wear eye protection and/or stay out of the plane of the blades during that test. Those plastic fans are often cracked
Good one!
Even better yet - I learned this method from my HS Auto Shop Teacher :cool:
Today, Helicopter Parents & Single Mom Karen's would probably have him arrested.
