2000 Eddie Bauer with transmission problems. | Ford Explorer Forums
jab46514
Elkhart, IN
'00 Eddie Bauer
Ok so my Explorer got stuck in the snow and as I was trying to get it out my transmission would'nt go anywhere when in drive. Reverse works fine and the lower gears. Any idea what this could be or is my tranny junk? Thanks for the help.
yes and its where its supposed to be.
Your thread was moved into the transmission section. Connect a 0-300 PSI test gauge onto the main pressure port, and the EPC test port. Take readings in every gear range. Bad valve body gaskets or loose valve body bolts could cause issues similar to what you're experiencing.
