jagbucket
- October 16, 2013
- tacoma Wa.
- 2000 mountaineer
Hello all: the items that do not work are windows, dome lights, puddle lights . and door chime sound. Found that the 10 amp fuse for the accessory delay was blown along with the lighter fuse in the interior fuse panel all others are good including the engine compartment box. I have remove drivers door and inspected the wires for breaks with no faults and no voltage in the blue/black supply wire, and have probed the wire as far back in the body harness as i can reach with no voltage found. checked the relays by the accelerator and all good with 12v supply present. Replacing the fuse did not fix the problem. I would like to inspect the harness but do not want to pull the dash to do so has anyone found a way to chase wires from center of dash to the door harness? will removing the instrument cluster help ? I have searched this and my problem seems to be other than the door connection. a wire diagram would be helpful so i could locate the splices for windows to interior light distribution Thanks for any help
