ebexp2000
- February 22, 2003
- Hartford, WI
- 2000 Explorer
Ok, I've done my homework already, but I'm still stumped here. It's a 2000 Explorer, 4.0 SOHC motor. No mods. 4.10 rear end. 5 Speed auto trans.
The engine has been pinging for some time now. It's a loud groaning noise, while in overdrive, especially when pulling the boat (approx 2000 lbs max). Even on the almost flat surfaces, pressing the gas pedal just a tad results in a loud groan (which I'm told is a ping). It then makes absolutely no power, and does not accelerate unless the transmisson shifts for more power. It also will ping without the trailer, but less.
The engine now has 66,000 miles. The lower-intake manifold gaskets were replaced at 50,000 miles, along with the chain tensioners. Also had the primary chain tensioner replaced. Have run sea-foam through the brake booster line several times, and although it helped slightly the first time, it's still pinging a lot. Premium gas helps, but not much.
Bottom line is that instead of making power under load, the engine groans loudly, which I'm told is pinging.
What should I do next?
