2001 Explorer backup system stopped working. | Ford Explorer Forums
vlpipkin
indpls, in.
2001 eddie Bauer
My 2001 EB explored backup (RSS) system stopped working the off light comes on every time it goes in reverse.Is there a way to tell which sensor is bad or what's causing the problem.
There are no fuses for the backup system labeled,I've seen other people discribe the same problem on newer vehicles and they all say it's a sensor but how do you check the sensors?
I checked the wiring unplugged the sensors and plugged them backed up no changed. Is there a way to check the sensors.
I had the same problem and it just started working again on its own. I'm curious to find out a fix too. My guess on mine (2000 Eddie Bauer SOHC V6) is there is a short somewhere, maybe under dash. I think I have some other issues there too because my cigarette lighter was blowing the fuse that is linked to the emissions/scanner testing plug in. Any help is greatly appreciated. Thank You.
