2001 Explorer died going up hill. | Ford Explorer Forums
KateL
Bumpus Mills, TN
2001, Escape Low
I was driving up hill and the Explorer died. When I turn it on the odometer reads the mileage, when I try to crank, the odometer shows dashes, the kick panel #7 10 amp fuse blows and you can hear the fuel pump start. This is the PATS/Restraint Control Module fuse. We've checked the ground wires, fuses, unhooked the seat belts under the seats, and the front sensor. The airbag light on the panel has been on for months. I hit the drivers side front hard turning into a driveway ditch in the pouring rain the night before. We're thinking it's wiring but we can't find a diagram. Hopefully, someone can share the diagram and ideas. Thanks
