2001 Explorer passenger side window not going up | Ford Explorer Forums
johnedward
florida
2001 explorer
I just want to get the window up. I could care less about the motor or switches. Can anyone direct me in the right direction? Thanks john
How about this, which leads on the switch should I use just to get the window up? I know which is the up and the down, but need to know where to touch the jumper to. Thanks.
Thanks Mountain, my boss told me the same thing, but I don't want to burn the motor. Would rather burn a 3 dollar fuse. Thanks again...John
if its the switch that bad, you may be able to pull a switch from one of your other windows and plug it in long enough to get the window back up.
Just jump the motor direct, you won't hurt it. I've put up several window motors this way.
