1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
VISIT US HERE FOR GREAT PRICES 2001 Ford Explorer Sport Trac Thermostat Housing Cooling Outlet Kit for V6 4.0L (to 7/24/00 production date)
FREE SHIPPING IN THE LOWER 48 STATES!!!
If your vehicle is leaking coolant around the thermostat, or your thermostat housing cooling outlet is broken or cracked, this could be your solution.
Kit Specifications:
Direct replacement
Replaces dealer part numbers: YU3Z 8A586 AA, YU3Z8A586AA
Kit contains:
(1) Thermostat housing / Cooling Outlet
(1) O-Ring
(1) Thermostat
(1) Thermostat outlet or neck
Built to strict quality control standards
Plastic construction
Fits the following Ford engines as listed per application:
V6 4.0L
Electrical sensors are not included. Buyer will need to reuse original sensors.
Correct only for models with screw in coolant sensor
Over time from thermal expansion and contraction the mating surfaces on the housing can warp or crack. If you are experiencing any of these issues replace your thermostat housing/ cooling outlet with our direct replacement part.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
OE #: YU3Z 8A586 AA
DORMAN #: 902-204
Kit Specifications:
Direct replacement
Kit contains:
(1) O-Ring
(1) Thermostat
V6 4.0L
1 Year Warranty
This part replaces:
OE #: YU3Z 8A586 AA
DORMAN #: 902-204
