wctrainer
- June 21, 2008
- Lake in the Hills, IL
- 2001 Sport Trac
I was putting a new wheel bearing on the passenger side of my 2001 Sport Trac 4x4 and I noticed I needed a lower ball joint.. since I had everything already off, I removed the tie rod and unbolted the lower ball joint but did not get it loose. In fact it appeared even if it did it would not separate from the spindle. I put everything back together and will attack it again. Will the lower a-arm separate from the spindle with the top of the spindle still bolted in? if it does, is there room to press out the ball joint?
Thanks!!
Thanks!!
