03Explo20
- January 4, 2013
- Jonestown, Pa.
- 2003 Explorer XLT
Anyone here ever have to change out a lower control arm? If so, could you post a "how to" quick reply here to match what I'm going to do below? I have to change out the passenger side arm as the bushings and ball joint are bad. I bought the whole arm from Moog for $90 so instead of having to dick around with ball joint tools and machine shops for the bushings, I'm just going to change out the whole arm.
Looks easy enough.......
Remove stabilizer links...
Remove lower strut bolt...
Remove lower ball joint nut and break BJ free...
Remove lower control arm to frame bolts...
My Explo is a 4x4 and I'm hearing the CV joint has to be positioned a certain way to get the arm off???
Any help or advice, guys, would be appreciated!
