Robert Walter
- August 16, 2018
- Canton
- 2002 Explorer Limited
Just the latest fix on my piece of crap Explorer. This one was easy... had a code (#34 flashing air bag light). Turns out it was a bad connector under the seat where it plugs into the chassis harness. The yellow connector plug was loose and shorting out. Pulled it apart and sprayed a little WD40 and I'm good to go. Now if my transmission, rear end, steering column, and leaking intake manifold were as easy. Never again will I buy another Ford! @@
