2002 Explorer. Driver's side window motor replacement. | Ford Explorer Forums
zenacom
boylston, ma
02 xlt
My drivers side window does not work, I replaced the window switch relay panel and that did not make a difference. I believe it may be the window motor. I would like to replace it with a new motor and wanted to know if any one has done this before.
Welcome to this forum! I've moved your thread into the stock 2002-2005 section. Check the connector on the motor to see if it has power when you hit the switch. If not, then it could have broken wiring between the door, and the frame.
thanks forthe tip ... i will check it out.
