NEWFS02X
- June 25, 2006
- Manitoba,Canada
- 2002 E/B 4x4
Moonroof on my 02 Eb is leaking as water is dripping from the rear ac dial area in the middle of the roof behind the front seats.Checked the drain holes and they are clear. I dropped the headliner from the rear to the front and I found out where the dripping originated. Looking at the rear of the moonroof housing where the rear drain holes are, there is a joint where the metal overlaps on the lower portion of the 'catch basin' about 2-3 inches inward of each drain tube attachment point. It's coming from there. I see the seal which slips onto the upper portion of the housing and seals to the roof. It's not coming out of there. It's leaking at the very bottom where the metal overlaps. Any idea what could be leaking inside? Obviously there's another seal inside there somewhere. Anyone lower that housing down before. I have the headliner dropped to just above the front seat headrests and I can see that it glued to a sort of blocking on each side above the driver and the passenger. The blocking is also glued to the roof it appears. Any help would be appreciated. New to the forum and looking forward to helping others out as well. I have a mechanical background and restore older mustangs ......thanks.......
