TheExplorerGuy
- May 16, 2012
- 2002 Explorer Limited 2wd
Good afternoon members. I recently got my hands on an absolute showroom mint-condition 2002 Explorer Limited with under 70k on the clock.
I have a few questions regarding the AC system. I'm a bit unfamiliar with Fords as I have always had my hands tied up in GM products. In a nutshell it's all the same.
This vehicle has the auto a/c with the steering wheel controls as well. I'm in Central Florida and the ambient temps are running in the mid to upper 80's with high humidity.
I find myself always needing to set the AC to at least 68 or below to get the unit to cool, and then even then it's still not pumping ice. The low side readings are under 20 at an idle using a cheap-o in-line gauge provided with R134 cans, again with the ambient temp 85+ on mac/recirc. Once I've been driving on the interstate for a long while it will finally catch up and cool things down. The compressor is not making any noise, and at night the thing will freeze my balls off. During the day the performance could be better.
I have a set of manifold gauges on the way and am awaiting the arrival to provide additional information. My best guess is that the system is slightly low on refrigerant and needs less than a pound, if that.
Any thoughts on the above?
Also, the remote temp and fan speed controls on the steering wheel do not function. The AC control head was replaced about a year ago by the previous owner (my inlaws) at a local Ford Dealer. Since then the controls do not function. Where do I start to diagnose this?
Regards
TheExplorerGuy
Regards
TheExplorerGuy
