gfestian
- October 24, 2010
- '02 Limited
Front left, nearly a rumble strip sound at mid-speed notable straight line, significantly increase Right turn with load transferred to Left wheel. Non-existent Left turn with load off the Left wheel.
I've read through 15 similar posts. They all end with either a wheel bearing or no resolution at all.
Following has been replaced
New Rubber all around.
New driver hub assembly.
Replaced CV axle (reman'd inner and outer joints)
Upper and lower ball joints are 6 mos old
Tie rod end is 6 mos old
I'm more stubborn than handy, so taking the knuckle down to the spindle 2 times is a lot of work.
Can anyone offer an educated guess?
