===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII===
===PCM DTC P0232===
Code: P0232 - Fuel pump secondary circuit High
Module: Powertrain Control Module
===END PCM===
===PCM DTC P1000===
Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
Diagnostic Trouble Code details
Check of all systems is not complete since last memory clear.
--Possible Causes--
- The vehicle is new from the factory and has not yet been through a complete OBD Drive Cycle.
- The battery or PCM has been disconnected.
- An OBD monitor failure had occurred prior to completion of an OBD Drive Cycle.
- The PCM DTCs have been cleared as part of a service process.
Note: The only way P1000 can be cleared (removed) from memory is when all of the OBD monitors have been successfully completed during normal vehicle operation.
P1000 cannot be cleared from the PCM when: 1. The thermostat is stuck open and a DTC is not generated. 2. There is an open VSS circuit and a DTC is not generated. 3. If the vehicle has a Power Take Off (PTO), the circuit is shorted to VPWR or B+, or the PTO is ON during Self-test.
The purpose of the Diagnostic Trouble Code DTC P1000 is to indicate that not all of the On Board Diagnostics OBD monitors have yet been successfully completed. You may also refer to the OBD Drive Cycle defined under the Powertrain Control/Emission Diagnosis Manual-Diagnostic Methods or the Owner's Manual.
Remember: It is not necessary to remove P1000 from the Powertrain Control Module PCM by driving the vehicle.
===END PCM===
===PCM DTC B1681===
Code: B1681 - PATS transceiver fault.
NOTE: The PATS module functionality can be integrated into various modules. (See the Module I.D. tagged to the DTC.)
--- Possible Causes --------
Passive Anti-Theft System (PATS) Module Signal Is Not Received
No transmission is being received on the signal return line from the transceiver module.
-Suspect PATS Module
===END PCM===
===RCM DTC B1998===
Code: B1998 - Side Airbag Open Circuit (Passengers)
Module: Restraint Control Module
===END RCM===
===GEM DTC B1818===
Code: B1818 - Rear wiper motor up relay circuit failure
Module: Generic Electronic Module
===END GEM===
===GEM DTC B1398===
Code: B1398 - Left Front Power Window Relay circuit failure
===END GEM===
===GEM DTC P0500===
Code: P0500 - VSS sensor circuit fault.
Open VSS circuit.
Shorted VSS circuit.
This DTC may be caused by :
Suspect VSS.
Worn or Damaged VSS drive gear on transmission output shaft.
Suspect PCM.
Faulty or damaged instrument cluster module.
===END GEM===
===RAP DTC ===
Module: Remote Anti-Theft / Personality Module
===END RAP===
===ABS DTC ===
Module: Antilock braking system
===END ABS===
