headusher
- May 17, 2007
- Nokesville, VA
- '02 Explorer Sport
Two months ago a very high pitch whistle started in the front end. The pitch and sound level remained the same no matter how fast or slow the vehicle was driven, whether in 4 or 2wd and whether brakes were applied or not or whether coasting out of gear. The whistle started at 10 mph and stopped when the vehicle stopped. The nioise went away as mysteriously as it appeared. However it was intermittent for the next few weeks. My mechanic couldn't duplicate the noise but said my front brakes were shot so he replaced pads & rotors. Didn't hear the whistle for over a month. THEN it started again. After some forum searching, discussions with various mechanics the concensus was that the hub assemblies needed replacement. Several hundred dollars later the noise started up once again after just one mile from the shop with brand new hub assemblies.
This time it's more of a chirping whistle that varies in pitch. Starts at 10 mph and doesn't go away until the vehicle stops. Had the rotor dust shields checked for clearance, spray lubed the dust shields behind the hub assemblies. Still have the whistle. Truck is currently back in the shop with two mechanics scratching their heads.
Need this mystery solved!!
