waskly
- August 21, 2010
- Crooklyn NY!
the left head guild is broken to peices...... you think a colision engine the valves are good?
best he can do is, drop the pan, drop the main bearings and connecting rod bearings and see if those are still good or blown up, if they are good, he just need heads timing gears.
he already pull the engine, we know timing is off on bank 2, left head, now on right head too.
check main bearings, connecting rod bearings, if they look good, just take heads off. and do a real check on valves. pulling cams does nothing.
motor is out easier to do headgaskets, heads now, then assemble it and it and find out it has a spun bearing. engine knock.
