jordan1948
- November 25, 2008
- Heiskell, TN
- 1994 Explorer 4X4 Limited
OK, what I'm dealing with is a ford escape that has a problem with the drivetrain. On the escapes the 4x4 has an "auto" or "on" selector switch. So that means that in "auto" the 4x4 will kick in when the 2 front wheels are sliping. Well the problem is, the 4x4 keeps kicking in when it doesn't need to and is making a thumping, thunking and clunking noise. The front drive shaft has been replaced as well as the wheel bearings. My theory is that with the limited slip differential the front drive shaft is slipping to much which in turn is causing the rear wheels to kick in. If anyone could help me with this I would greatly appreciate it.
